If you have two devices and one 15a curciut, could you install a three way switch bewteen them??
By puting the hot lead on the traveler and the two switchlegs on ether device... the neutral on each device tied together.. the switch would turn one on and the other off...
the devices are a 1000 watt heater and a 1000 watt hot water on demand heater... So the room heater would be on most of the time... The heater has its own on/off switch..
YES, I could use an ON/Off/ON switch... but would the standard three way work...
