Wiring through concrete wall
I'm installing exterior lights on a small commercial building. I was going to use 4" octagons in the block outside and run through the block to the interior. This wall will be poured with concrete. Do I have to put this in EMT?
Re: Wiring through concrete wall
I know I can't run just individual conductors through there...
Sorry, maybe I didn't explain very well.
I just didn't know if it ok to run MC cable through there even thought the inside of the block will be poured.
In general, it can't. See section 330.12(3) and the FPN. You could always sleeve the MC with a suitable raceway.
Since the conduit, etc., will be embedded in concrete, thing of it as a permanent concrete form. You can then feed any approved wiring method through the passageway, whether individual conductors or a cable assembly.
