I need to place a number of outlets and lights on the outside wall of a residential concrete home.
I need to drill through the concrete to feed the NM wire to the outside boxes.
Code (334.12) says wire "embedded" in concrete must be sheathed/protected, which I assume means conduit.
Code also states I can run wire in a masonary "chase" without protection.
Code does not define Embedded.
Is the wire through the wall be Embedded, or in a Chase?
Thanks.
Thanks.
