albrechtmyers
- Glenolden, PA
- Electrical Contractor
Hello
I'm about to start a complete house refurbishment, including rewiring and insulating between floors.
As I understand it building regs require you to drill holes through the center of joists 0.25-0.4 along the span of the joist - this is going to put my cable run ~75cm away from the wall. Joists are 180mm high - I intend on completely insulating the void between ceiling/floor.
In an ideal world, I'd like to drill my holes right next to the wall so cable passing through joists are adjacent to walls. Cables running in the direction of the joists would be supported by P-clips allowing fast & easy installation. Installing the insulation, the cables would then be touching the joist/wall and could be argued as being installation method 100/102.
With my cables ~75cm into the room, will I either have to leave an insulation gap around the cables, or install a conduit between each joist and call it method A*? Or do I notch the joists (will have to be the bottom of the joist) and can this be classed as installation method 100/102?
Do cables have to be tightly clipped to joists along their run, or is running them in P-clips and pushing them against the joists with the insulation acceptable?
