Within sight
codequestion
Banned
MD, USA
If air conditoning disconnect in panelboard is located in same room no walls between as unit but when you face the unit the panelboard is behind the person but within 50 feet of the unit then is it considered to be within sight per code?
Sent from my SM-G935U using Tapatalk
IMO, yes however, years ago I did get red tagged for that. Install a disconnect and be done with it
BTW, how can an a/s unit be inside a room? The unit must be outside
Condensor unit is outside which has disconnect of its own but has indoor unit both connected to same circuit in panelboard.
