electricman2
- North Carolina
- Retired Electrical Contractor
Service Call. HO says after bathroom remodel,GFCI outlet is dead also outside receptacle. Here is what I found.
The two black wires came out of the wire nut when I pulled receptacle out. It gets better!
Old style GFCI with leads. Hot wire in box spliced to ground wire. Both hot wires,(line and load) spliced together to hot wire going to outside receptacle. white wire came out of wire nut too. EGC in box not connected to anything. Found out that whoever put up drywall removed receptacle then replaced it after sheetrock was up.
