I am installing a wood pole with two 400 watt metal halide fixtures on a "bull horn mounting bracket with slip fitters".
I can use UF cable to connect the fixtures but i was wondering can I use flexible cord "hardened type"
The problem is the mounting bracket does not have a conduit entry so i will run two seperate cables through the bracket to each individual light.
just wanted to know if flexible cord would be a better option?
