working above church pews
fourteen/two
Richmond, VA
Looking at a job changing out chandeliers in a vaulted ceiling
Problem is the church pews are right below the lights.
Light boxes are 22 aff.
A JLG lift to reach up and over the pews is $900 for the week
But weighs 15K pounds, and I'm uneasy driving it on the slab and the carpet
A gennie lift with a "pew spannder" is $900 for the week
weighs less but looks to be much more labor intensive moving around
A rolling scaffold would be ideal, but looks like it wouldn't fit between the pews
Anyone care to share their experiences in changing out lights in a church?
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Moving a row or two is out of the question?
480sparky
Iowegia
Some churches have already purchased their own special scaffold systems to allow the maintenence crews to work in the sanctuary. Ask the church if they have such a system.
fourteen/two
Richmond, VA
the pews are bolted to the floor and are removable, I rather not get into removing them.
15' long and looks the the carpet was installed after the pews, so not sure what would happen to the carpet once a pew was removed
chris kennedy
Miami Fla.
And no doubt very heavy. Ask the church staff to move them. Worth a shot.
Mule
Oklahoma
If its not too high of a ceiling and fxtrs are not huge, I have turned "Folding tables" upside down and laid them on top of the pews, then put a tall 10ft step ladder on that, having some one watching the riggn below......Kinda hillbilly, but it worked for me...Obviously if it is too high or too heavy for this method....DONT DO IT.:D
OOPS I just seen the ceiling height....this aint the fix....LOL !!!
fourteen/two
Richmond, VA
Folding tables?
Folding tables?
I was having a similar idea.
Plywood, 2x4, etc over the pews for a platform
The pew is 28" to 36" tall
A 14' ladder
A 6' electrician
Could work
peter d
New England
A 14' ladder
A 6' electrician
Could work
I would have called for the lift and be working before you even start rigging up that mess. If you're worried about the lift damaging the carpet, throw down some sheets of cheap plywood.
electricmanscott
Boston, MA
I am not a church going type but I thought you could just pray to make things happen??
Oh the things I have done in my foolish younger years and lived to tell. Dangling over church pews is one. :rolleyes:
I would not even consider the job unless they were willing to pay whatever it took for a proper scaffolding setup.
There are companies that do that sort of thing if you'd rather not.
Is your life really worth giving up for some stinkin' light fixtures. Mine isn't. Close but not quite.
1793
Louisville, Kentucky
Inspector
Amen to that.
raider1
Logan, Utah
I agree, a few years ago one of the people that I worked with went out to work in a chapel and rigged up some unsafe scaffold. Needless to say, he had the scaffold tip over while he was climbing up and landed face first on a pew, thirteen fractured teeth later he decided that wasn't the best idea.
safety first.
Chris
mdshunk
Right here.
I do churches quite often, and there's one lift made purposely to get between the rows of pews and is light (in weight) on the floor. The Genie 1-man lift with the "Super Straddle" attachment. I've gone up to 52 feet in the air with that rig, on a wood floor with a basement below. Didn't have to unbolt one single pew. Next time you guys need to know about a weird tool, save some time and just ask me! Ha ha. :)
1793
Inspector
Looks great. Do your Local Rental places rent these and if so about how much? How difficult is it to move?
480sparky
Iowegia
A 14' ladder
A 6' electrician
Could work
Sounds like something The Professor would build on Gilligans' Island.
Or something you'd see in a third-world country.
fourteen/two
Richmond, VA
Genie Lift
Genie Lift
I was just checking out that very lift. The way the guys at the rental place explained to me it was a big cumbersome, complicated jig.
But having googled a few pics of it, its looks ideal for what i need.
mdshunk
Right here.
No way is it cumbersome or complicated. It's a one-man affair, but it is easier to use if you have two men for the initial setup. Once you get the quick 5-minute lesson on how to set it up, it's a snap. Once it's all adjusted for the particuler pews and the straddle height is set, all you do is go up and down in it, and push it around.
For the manlift and the Super Straddle accessory, it's about 500 bucks for 2 weeks. Both places I normally rent from have them, but they normally need a head's up on when you'll need the Super Straddle accessory to maybe pull it from another store. This is stuff you'd want to pay a couple extra bucks to have delivered and picked up.
mdshunk
Right here.
The genie one man works well, but if you have to make a lot of trips assembling and installing a ground man is a necessity. Especially when you are 6'2" and 235 like me
I agree, no matter what size you are. Pair of radios too. Hollering doesn't really seem like a good thing to do in a church. If you have some buckets you can hang on the outside of the basket, that helps too.
