makoester1
- Indiana
Does it contain items that are "likely to require examination, adjustment, servicing, or maintenance while energized"?
If it is only a switch - many places don't require it to have "working clearance".
I believe there would be occasion to open this switch while energized. I would move the conduit.
I don't think merely operating the switch triggers the working space requirements.
What about the possibility of arc-flash when opening/closing the switch?
what about it? how would the working space change the IE any?
Have you ever heard of 'fall-back' clearance?
No such thing in the code.
In any case you cannot fall back fast enough to do any good in the event of an arc blast, no matter how much clearance you have.
If you are truly concerned there is an actual risk of arc blast the only way to safely operate the switch is with some kind of remote device. Put a long pole or rope on the handle and open it while you are outside of the danger zone.
I don't see the arc flash warning sign in this picture. It must be at the top where the picture cuts off, but that distance might not be all that much. perhaps a few feet.
'Fall back' is common knowledge in the electrical business and part of the strategy in development of working clearances. Arc flash warning signs - whether present or not - wont have much affect on the laws of physics.
Not only is this a Code violation, it is also a OSHA violation as it is clearly a tripping hazard, most likely in line with egress.
disconnect switches, transformers, not included in dimensions in 110.26
Transformers don't require access and are never worked on while energized. Switches are a different story.
Never???
the only work OSHA allows to be done live is essentially for debugging. One would need full PPE required for the level of IE. the PPE that is required would protect the worker from the arc blast.
so again, how would a platform or moving the conduit make it any safer?
No one allows a large diameter conduit to be placed directly in line with a walkway - clearly impedes egress and is therefore an OSHA violation. It also infringes upon working space criteria per 110.26. If I were inspector, I would fail this immediately and write an RFI to engineering.
Disconnect switches are not included in 110.26e. A toggle switch is a "disconnect switch".Transformers don't require access and are never worked on while energized. Switches are a different story.
Actually, the conduits look like they are in the best place to not be a tripping hazard. Anyone walking on "the roof" without a blindfold would notice the step up or down and the conduits at the same time.Looks to me like a large fused safety switch. Regardless - the conduit has to be moved - it’s a tripping hazard and therefore an OSHA violation.
