Any rack-mounted UPS system would need maybe 24-36in of clearance either front or rear for battery swaps, but that's about it.I am less certain as to whether a UPS would require maintenance while energized.
Good point. It reminded me that the IT world has their own requirements for space in front of, and behind, their racks. I am not certain I can correctly recall the numbers, but I believe it is at least 24 inches all around. It has to do with convenience, rather than electrical safety.Any rack-mounted UPS system would need maybe 24-36in of clearance either front or rear for battery swaps, but that's about it.
Generally it's 48in to the front to install into or remove equipment from a standard rack, and 24-36in minimum to the rear (though every server room I've been in has provided 48in). Rear clearance is more about having space to work on cables and interconnects comfortably. Networking hardware is notorious for having all their connections on the "wrong" side, though, so it's pretty common for that to be mounted on rear rails rather than front.I am not certain I can correctly recall the numbers, but I believe it is at least 24 inches all around. It has to do with convenience, rather than electrical safety.
It's not a rule or code but yes, space is needed.Good point. It reminded me that the IT world has their own requirements for space in front of, and behind, their racks.
