Dan Kissel
- st louis, mo
We build control panels that are supplied to control 480 vac motors and other devices. We use 24 vdc for control circuits. The panels will be installed where there is normally over 1.2 cal but less than 25 cals of incident energy available. If make our enclosures a 2 door and separate the 24 from the 480, with the 24 behind one door and the 480 behind the other door, can the 24 vdc side be worked on hot if the door on the 480 is closed. Would a partition make a difference? Can I work on the 24 vdc side if I am outside the arc flash boundary? I realize we could build two separate cabinets but the customer is in a very competitive industry and is asking why can't he work on the 24vdc side.
