Grouch
- New York, NY
Hi all,
I have questions regarding Article 110.26 of the 2008 NEC (should apply to other versions). Let's say the incoming service into my electrical room is 277/480 volts. If i have 277/480 volt equipment facing each other, I need 4 feet clearance between equipment based on condition 3 (table 110.26(A)(1)).
My questions are:
1) there's step down transformers, and now i have 120/208 volt equipment in that same room as well. If I have 120/208 volt equipment facing each other, can i apply 3 feet clearance between this equipment, or does the 4 feet rule apply throughout the entire room?
2) What if my 277/480 volt equipment is facing 120/208 volt equipment? do i use 3 or 4 feet clearance between them?
3) What if my 277/480 volt equipment is facing 12 volt DC UPS batteries? how many feet do I need between them? How do you treat it when you have DC facing AC?
4) Table 110.26(A)(1) says these distances are based on nominal voltage to ground. so let's say my equipment is 480 volts (without the neutral, so we don't have 277 volts)... if i have 480 volt equipment facing each other, does condition 3 apply?.. that would give us 4 feet between the equipment... but since there's no 277 volts, does this table now apply?
Thanks for the help!
My questions are:
