rexowner
- San Jose, CA
- Electrician
My question is about the interpretation of the access and working
space required in front of equipment.
This is on a residence, with a 26" wall (outside corner
one one side, window on the other) to put the meter main.
The architect wants to hide the meter by building out
a box with a door on it that (internal dimensions) will
be 20" wide and 18" deep. When the door is opened, the
front of the meter main will be 11" back from the
opening. So the front of the cabinet sits in an
opening that is only 20" wide and 11" deep.
This is OK with the POCO, since it is based
on their reqirements drawing (it is on page 6 of
section 5 of their greenbook):
http://www.pge.com/includes/docs/pd...truction/greenbook/servicerequirements/05.pdf
That drawing pretty much exactly shows what is proposed, except
there will be plenty of height up and down.
I am not so sure about interpreting the NEC requirement.
If I literally read 110.26, I thought working space
starts at the front of the panel, so this 11"D x 20"W area
does not allow working space.
Realistically, though, if working space is for personnel,
I will have no trouble installing or servicing the meter
main in this box, and there will be adequate working
space in front of this wooden box for someone to
stand and work. So, working space would start outside
of the wooden box, rather than
the front edge of the panel.
I have worked on other installations that are similar
but I have always wondered about 110.26.
Does the box violate the working space requirement
or is this fine?
or is this fine?
