Can those be used for NM cable?
I don't have a box here, so I don't know.RELATED PRODUCTS
Connectors covered under Armored Cable Connectors (AWSX), Conduit
Fittings (DWTT) and Power and Control Tray Cable Connectors (QPOZ) are
also suitable for use with nonmetallic-sheathed cable when specifically indicated
on the device or carton.
Can we just terminate flex / cable to light fixture without using connector or elbow?
Can we run the cable through light fixture housing directly and make the wiring connection inside without using connector? I think we only use connector when we run hard pipe conduit? Correct me if I am wrong.
