Re: Working Space
NFPA 54 requires 3 feet to any spark producing device but an electric utility's cash register (
meter) is not a spark producing device unless you pull it under load. I would assume that if you standing in the area with the strong smell of gas, you would not pull the cash register.
Since the meter fitting is not service equipment, 110-26(e) in the 1999 Code does not apply (
this has no changes for the 2002 Code).
With all that said, the serving electric utility will have some rules of their own that will require some clearances that may exceed anything in the various Codes. Please check with their book of rules (we call ours the
Electric Service and Meter Manual). We require all the clearances shown in 110.26 plus 4 feet in front of the meter fitting. We also require 3 feet of clearance to any gas meter.
