goldstar
- New Jersey
- Electrical Contractor
That's a good one too. The sad part about the one I posted is that it's the third one I found in the same community. It's a lake community and many people built their own houses way back when. I don't think the issue is so much "why did you locate the breaker panel there" as much as it is "why did you locate the kitchen there". They could just as easily have located the breaker panel in the basement (even though it's slightly higher than a crawl space).Here is my all time favorite sub panel. Take you back to 1950 when this thing was thought to be a good idea...someone is filling the sink to do dishes and the phone rings...sink has no overflow except to well overflow :lol:
The worst one i had was a old residence that the new kitchen remodel involved putting cabinets over the panel. At leats they cut the back of the cabinet outand made the shelves removable but you still were working in a cabinet to access anything in the panel
Same realtor bought a house and the panel was in the wall, hidden behind paneling which backed a built in bookcase. To get to the panel one had to remove everything from a couple shelves, pick up the shelves and take them out then tip out a piece of paneling to expose the panel.
What moron did this. What made this guy think it was ok.I had a house in Seattle that was built in 1906 without electricity, it was added probably some time in the 1910s. The breaker panel was cut-in on the outside wall in the back and although they used what was probably a WP box, they mounted it deep into the siding, so the cover would not fully close. I bought the house in 1985 and it had been that way all along, breakers exposed to the weather. Of course I bypassed it and put in a new indoor service, but Seattle City Light did not re-use the old service drop, they just gave me a new one. When I went to remove the old one, it was still live on the line side of the old meter socket! After 3 years of harassing them to kill it, I gave up and nailed a big box over the whole thing. When I went to sell the house, that got red-tagged of course, and that finally got SCL to disconnect the damned wires at the pole.
Here's one a friend in Texas sent me from a general contractor that did his deck, but used as an example of bad decisions...
Nothing wrong with the bare neutral - if it is a service conductor.A lake house.. Actually a 1950's mobile home with a house built around it. A 200 Wadsworth panel is located under the bathroom vanity. A #6 bare neutral is provided by the POCO.
Looks like that could use a cabinet covering half of it.No breakers but really???
Look at both pictures carefully, it had a cover in the top pictureLooks like that could use a cabinet covering half of it.
