Gounded
- washington dc
I tried looking for an answer to this question, but couldn't find easily.
Somewhere I read that 4 1/0 might be better as far as current carrying capacity since it gives more surface area (so heat dissipation is better). But then, if you use this for, say ground conductor, and fault happens, will the integrity and strength of the ground conductor be same to withstand that fault? Since fault could travel any path, is it possible it only goes through the first conduct (1/0) and not the rest, thus damaging the conductor?
