I've had a bit of an argument with someone over a video which I will link below.
In the video, a man is standing on top of a boat which is loaded on a tractor trailer. His job appears to be lifting low-hanging cables which otherwise wouldn't clear the top of the boat as the tractor drives down a street. Everything seems to be going fine until he grabs the cable with his other (free) hand, after which he suffers an apparently severe shock. The argument I was involved in was a dispute over what it was that shocked him. Another cable can be seen above the man's head, and from the perspective of the observer, it appears to be directly over his head. Not only that, but the shock occurs almost exactly at the moment when the observer's view of the cable is obstructed by the man's head. However, looking at the delta of vertical distance between the utility pole connections of the two cables, it seems to me to be impossible for the topmost cable to be anywhere near his head unless it had an absurd amount of sag.
I'm having a difficult time rationalizing what else could have caused the shock, and that's the genesis of this ridiculous thread title. Since the shock occurred very shortly after he grabbed the cable with his second hand, I wondered if the potential difference between two points (roughly a meter) on a single HV cable could be great enough to cause a severe shock. Alternatively, if instead of an incredibly small distance (less than an inch?), a bird's feet while perched on a distribution line were separated by a meter, would it be turned into a crispy critter?
Any speculation about what happened in the video is obviously wholly welcomed. I am convinced that the topmost cable couldn't possibly be close enough to come into contact with this man's head.
DISCLAIMER: IN THIS VIDEO, A MAN IS SEEN SUFFERING A SEVERE ELECTRIC SHOCK, POSSIBLY ELECTROCUTION. VIEWER DISCRETION IS ADVISED.
https://www.documentingreality.com/...arrying-boat-lifts-high-tension-wires-194702/
