Building (B) will be expanded for addition of few rooms and an elevator. A new subpanel will be required to feed its new load , currently the power provided in building (B) is not enough to support this new addition to it so that is why a new panel is being added to the renovation part. Building (A) is where the main panel is that is feeding all the other buildings. My question is since this new subpanel is being fed directly from the main service panel building (A), do i need a new ground rod for it or do i just connect it to the existing (B) (if there is one which i'm not sure where it is) ground rod and run a ground wire from the main panel to it? Thank you
