hockeyoligist2
- close to greenville sc
A new pump is being installed in a sewer basin. The aerators will not be used when the pump is in use. It will be used to pump out the basin after the level drops to about 2 feet. The aerators have an automatic level cutoff. The pump is only 6 amp (100 amp circuit the aerators pull 30 amps) so wire size is not a problem. Can I tap off of the aerator circuit to supply the pump? I have read the tap rules in the NEC and I can't find find a violation, did I miss something?.
