1793
- Louisville, Kentucky
- Inspector
allenwayne said:What brand of panel are you using.Most probably all make an add a lug that is used on the neutral bar for larger wire than the opening will accept.
From a chemistry/physics standpoint, likely none.1793 said:... what problems I might run into, bimetallic corrosion or dissimilar metal reaction ...
I think Siemens and Sq D both make a lug like that, only instead of a "box with a circle in it" to mount it, it has a forked end designed to use two spaces in the neutral bar. Be persistent, walk behind the counter with the bozo and help him find it.1793 said:
SQ D homeline panels even come with one in the box.I`ve seen them for QO`s also and i believe CH has them as well.georgestolz said:I think Siemens and Sq D both make a lug like that, only instead of a "box with a circle in it" to mount it, it has a forked end designed to use two spaces in the neutral bar. Be persistent, walk behind the counter with the bozo and help him find it.![]()
Yea, you can even get these in DIY-land (i.e., the Big Boxes).georgestolz said:I think Siemens and Sq D both make a lug like that, only instead of a "box with a circle in it" to mount it, it has a forked end designed to use two spaces in the neutral bar. Be persistent, walk behind the counter with the bozo and help him find it.![]()
