If you find a hole cut in a 1 hour firewall and you need to add a cable through that wall would you have a problem using that hole if you notify the building Manager of the hole before you use it, they acknowledge it as a problem and they state they will be patching it. They allow you pass your cable through it, prior to patching, sealing it. I would not be there when it's getting patched.
