We call them both.ultramegabob said:do people call those a gang box in your area? around here its a handi box, and a gang box is a large metal container you put your tools in on the jobsite.
wbalsam1 said:The flush handle of the toilet pushes down on a threaded rod that goes to the floor to a small see-saw switch which is hooked to another rod that extends all the way up to the ceiling bucket fan and connects to the pushrod that goes through the ceiling into the handybox switch which then turns on the bucket fan which exhausts the odiferious fumes at approximately 600cfm into the attic space. Stepping on the small see-saw switch with the left foot reverses the phase and neutral connections which reverse the air flow back into the bathroom. Patent applied for and under consideration by an esteemed panel of experts.:grin:
GMc said:Hard to tell by the picture but is the box mounted to what looks like a top plate of a wall? If so maybe that wall is where a pocket door once was or is still there.
GM
Oops. HTML is turned off in this forum. Try using vB code instead, like this:tomspark1 said:<a href="http://www.rubegoldberg.com">Rube Goldberg</a> woulda been proud...![]()
LarryFine said:Oops. HTML is turned off in this forum. Try using vB code instead, like this:
[url=http://www.rubegoldberg.com]Rube Goldberg[/url]
It will look tike this: Rube Goldberg
The only reason what I typed does not appear as you want is because I used the 'noparse' code.
