Re: WP GFI Receptacle
If multiples strings of lights are going to be used out side the only way I have found to seal the plugs is with a dielectric grease made for this purpose use it to coat the plug prongs where one string plugs into another. and some types of this grease is high temp rated and could be used to seal the lamp sockets too. But be sure to get the type that is non-flammable. as this could just add to a problem. I have found that even 3-M scotch-33 will allow moisture in the connection.
Item ID: 30-030
Name: Noalox? Anti-Oxidant Compound 8 oz. Squeeze Bottle
Features: Anti-oxidant and anti-seizing compound
Reduces galling and seizing on aluminum conduit joints
Suspended zinc particles penetrate and cut aluminum oxide
Carrier material excludes air to prevent further oxidation
Improves service life of aluminum electrical applications
For use with all types of pressure-type wire connections
