I still didn't get an exact answer to this question: here is it again.
you have 3 single phase transformers arranged in an ungrounded wye primary and centertapped delta secondary. Assume the center-tapped transformer with leads L1, N, L2 is in the middle and the other two transformers on either side with their wild leg P tied tied together.
Now, when the primary winding on the transformer on the left side or right side of the centered tapped is shorted but not to ground what will be the voltages between :
L1 & L2 =
L1 & N =
L2 & N =
P & N =
L1 & L2 =
L1 & N =
L2 & N =
P & N =
