KSFEngineering
New member
- Goddard, Kansas, USA
I've been researching this for a couple of days now but haven't found a diagram for my specific situation. I'm currently installing a waterjet system that was originally running on 230V 3-Phase and I'm converting it to 460V 3-Phase, which means changing the wiring to the motor (which is a 50HP motor) from low voltage to high but the diagram on the motor box has me stumped. I've hooked up hundreds of regular 3-Phase motors in the past but I've never come across a Wye - Delta starter setup. So, I have 6 wires coming from the starters, one starter has an overload attached to it and has 3 wires (labeled U1, V1 and W1, in that order from left to right), and then there's 2 starters that are mechanically and electrically linked and has 3 wires coming from them (labeled W2, U2 and V2, in that order from left to right). Now inside of the motor box there are 12 wires and the diagram for high voltage shows the schematic for Wye Start - Delta Run. I will add pictures to this post as well, but I just need to know how to connect all of the wires correctly. I appreciate any assistance you can give me so I can finally start cutting some parts!
Here's a general view of the starters/contactors
This is the single contactor with the overload (U1, V1, W1)
This is the bottom of the linked contactors (W2, U2, V2)
This is the diagram on the inside of the motor box (wiring for high voltage - 460V)
