I'm looking for some pros and cons with using a wye-delta starter vs. a soft starter for 480V motors.
First I know that wye-delta starters require a 6-lead motor so if the motor is not a 6-lead motor then a wye-delta starter is not an option.
In terms of cost I would imagine that a wye-delta starter is significantly cheaper and would guess that both take up roughly the same real-estate in an MCC or enclosure?
I think the one negative of the wye-delta starters is the open transition between wye and delta and the current surge that comes with this where a sotstarter is able to provide a controlled ramp in order to avoid this current surge.
Are there any HP limitations where for larger HP's one would be better than the other?
