JasonCo
- Houston, Texas
I have a diagram, where my primary is a Wye 3-phase 277/480 volt system. And my Secondary is a Delta (Volts not given in the diagram). The Diagram shows all the 3 lines connected to each phase of the transformers. The diagram shows 3 ammeters connected in the middle of the lines on all 3 lines that shows the amps of each line.
The question is: If Ammeter 3 indicates 45.8 amps, the duct heater (3 phase Duct Heater in Delta) is delivering ___ kW of power.
Answer choices:
A. 26.443
B. 12.687
C. 10.480
D. 21.984
E. 38.077
Okay two ways I can think of doing this, I am just confused though..
First way is 45.8 x 1.732 x 277 = D as my answer.
Second way is 1.732 x 45.8 x 480 = E as my answer.
Very confused though on the theory of all this. Firstly, if I have a Wye system and E_line = E_coil x 1.732.. How is this possible. I understand line to line would be E_coil x 1.732 but looking at the diagram, Line 1,2,3 is coming out of the 3 end points of the wye transformer. So if I read the volts on the line (E_Line) it should be 277 not 480... If I read line to line it would be 480 though... But the equation is E_line = E_coil x 1.732.. Just very confusing to me.
Edit: The diagram shown in this thread is vaguely what I am trying to describe, besides the volts are different though. Just wanted to show the 3 lines all connected to the Wye - Delta accordingly. http://forums.mikeholt.com/showthread.php?t=122813&page=2
Answer choices:
A. 26.443
B. 12.687
C. 10.480
D. 21.984
E. 38.077
