Bigbossman
- Midwest
- Electrician
I need to install a 2 HP 3 phase motor 230/190v. There is an existing disconnecthat has 195v per phase, The supply voltage 120/208 goes through a buck boost step up transformer. The transformer however is Delta but the input voltage is Wye. The input has no neutral and motor does not require one. Two questions is the 195v on the secondary considered Wye voltage or Delta voltage and will the motor work properly with the voltage?
