mikeames
- Gaithersburg MD
- Teacher - Master Electrician - 2023 NEC
Educate me here.... Is it possible that the magnetic field built up in one state is collapsing and when the other state is closed the field then conflicts with the incoming current. Maybe not so much of an inrush but and outrush... I remember as a kid I played with a 12 volt relay transformer. Every time I removed the power leads I would get shocked. I soon learned and realized that this was the field collapsing in and causing a significantly higher voltage then what was put in.
