Please provide any information on wire sizing for wye start delta run motors. The 2002 NEC states in 430.21(c) that the conductors on the line side of the contactors should be sized based on the motor FLC, I assume that the 1.25 multiplier should be applied to the FLC before chosing the conductor size is this correct? NEC 430.21(c) then states that the contactor load side conductors should be based on 58% of FLC, should the 1.25 multiplier also be applied after the ampacity is reduced to 58%? I am working with a vendor to make sure we size everything correctly so any documentation that could be used for reference material would be appreciated.
Thanks
Thanks
