Re: wye voltage calculations
Originally posted by jimmie: I guess what I'm asking is which one is the base voltage?
There is an analytical technique that applies to three-phase systems, and that makes frequent use of the terms, ?base voltage,? and ?base current,? and ?base apparent power,? and ?base impedance.? The technique is called ?per unit analysis.? Are you using the term ?base voltage? in this context? If not, then you may disregard the next two paragraphs.
If you are, then I have two answers for you. The first is that you are free to choose any two of the four terms listed above, and then you calculate the other two. If you were to choose ?base voltage,? you must make the further choice of ?line-to-line voltage? or ?line-to-ground voltage.? The correct answer to your question, then, is this, ?There is no ?base? quantity until you choose two of the four, after which you are no longer free to choose the others (i.e., they are to be derived from the first two.?
My other answer is that there is one set of quantities that is almost always chosen in any analysis. We look at any transformer in the system, and we choose its KVA rating (or MVA rating) as the ?base apparent power,? and we choose its secondary line-to-line voltage as the ?base voltage.? All else follows from this choice. In this case, the correct answer to your question would be ?208.?
If the above discussion does not help answer your question, then I will offer one more perspective. The
ABSOLUTE TRUTH of the matter is that when we say ?120,? and when we say ?208,? we are being imprecise. I might even go so far as to assert that we are being sloppy. Both numbers are commonly used in conversational English. But both are incomplete, and both are sloppy. The right thing to say, the true thing, the complete thing, the precise thing, is to say ?120 volts line-to-ground? and to say ?208 volts line-to-line.? Then it becomes clear that the two phrases convey identical information. If one is true, the other is also true. If one is false, the other is false. Neither contains more truth than the other. But we seldom use these two complete phrases; we just say ?120? and ?208.? But if we at least think of the two numbers as being part of the two complete phrases, then we can avoid any confusion.
