M Maynard Williams New member Nov 15, 2006 #1 what is the best transformer connection and please describe why.
D dsteves Senior Member Location Appleton, WI Nov 15, 2006 #2 The answer depends greatly on the intended application. Do you have one in mind? Dan
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Nov 15, 2006 #4 As a source, Delta/Delta is better, because each winding sees only line-to-line loads, and each load is connected to only a single winding. (<-- Opinion only)
E edamico11 Senior Member Location NJ Nov 15, 2006 #5 Maynard Maynard You may want to read this in addition to the comments http://www.mikeholt.com/mojonewsarchive/EC-HTML/HTML/WyeTransformerCalculations~20030916.htm
