Dave Colton
- Pa
- Electrician
On a 3 phase wye-wye auto transformer do I have to connect the neutral if the load doesn't require a neutral?
Thanks
Thanks
Yes, you need the source neutral if you want the transformer to perform correctly during imbalanced loading.On a 3 phase wye-wye auto transformer do I have to connect the neutral if the load doesn't require a neutral?
Thanks
To be clear (since I am not completely sure what you are saying):Thank you. So neutral on the primary and the secondary neutral should be left floating?
