The key to the question is the 70 deegrees C. The correction factor for 70 degrees C is .33. So if you take the allowable ampacity of the THW conductor at the 75 degree column (25) and multiply it by the correction factor of .33 because of ambient temperature of 70 degrees C you come up with 8.25.
But the original post indicated "temp70'c." I would have a hard time seeing some one using 70 degrees fahrenheit when it was indicated "C". Also most of the time when using the NEC we are dealing with Celsius.
