I am taking a stab at laying out an electrical room however I have a 150kva xfmr 480-208Y/120V, when entering and exiting the transformer (EE dry type) with a flexible connection how Is it typically installed? My curiosity is more on the secondary side where the secondary is a parallel set of 350?s to a DP located adjacent to it I am trying to determine the distance between the xfmr, and the distribution board seeing how the secondary exits the front right side of the far and is about 28? off the wall however the DP only being 12? deep how do you make the transition (back to back bends) to get into the panelboard with having significant distance between the two?
