martsco11
- Anaheim, CA US
I repaired a conduit the other day with 3 phase 480v feeding a 30KVA xfmr (120/208v). Although I did not have to open the xfmr or panel to make the repairs, the colors of all three #8 wires (primary) were black. The ground wire (#10) was easy enough to depict. After the U/G repairs, I terminated the wiring, energized the system, and found all voltages proper to neutral, ground and phase to phase. A co-worker mentioned I should of properly phased the primary to the XFMR. I retorted "The XFMR is not a motor, therefore phasing is just good practice, not a necessity." H1 brown H2 Orange H3 yellow. Question: Will this actually have an affect on the life of the XFMR if I accidently put the "C" phase wire (yellow) to H1 or H2, and why? No motors, or 3 pole breakers on the secondary side.
