sparkytcc
- Kamas, Utah, USA
I am installing temp. power to some office trailers for a jobsite. I was given a temp. power board that has 6 100 amp fused disconnects and a 150kva 480pri to 120/240 sec. installed on it. the sec. is all wired up with parallel 3/0 from the sec to a tap box with distribution blocks and 6 sets of 2awg from the distribution blocks to the indivdual disconnects. my question is if i used a 200 amp fused disconnect on the primary with 4/0 conductors does this violate 240.4(F) or is ok per 240.21(C)(2). note the sec conductors are less than 10ft. and the calculated load is 80kva. thanks for any info
