spearxspark
I am trying to find out if you can,by code come off the secondary side of a transformer twice to feed two 100A panels.The xfmr will be located outside two temporary construction trailers. Xfrmr is 75 kva 480/240 3 ph. Secondary wiring will be in rmc.Panels are 100A single ph 120/240 panels to be used for temporary power to the work trailers, lights /receptacles/air and or heat. I would like to use lugs designed for parallel wiring to come off the secondary side of the xfrmr and run one pipe to each panel. Is this acceptable by code? I have not been able to locate this in my nec handbook. Any input would be great.
