Hi all-
Sorry, but I'm a little rusty here. I was wondering if anyone could check my reasoning and make sure I'm not off track?
I'm installing a 30kVA 3-phase dry-type transformer at a warehouse on a 480/277 Y system. The transformer is 480 delta primary to 120/208 Y secondary. The mfr told me I can use this so long as I don't make a neutral connection on the primary side; just bond the neutral (X0) to ground on the secondary side. Does this seem correct?
Secondly, I wanted to make the entire capacity of the xformer available for use in the building. I calculated a primary circuit breaker size of 50A (30kVA/{480x1.73} plus 125%) and 125A on the secondary side (30kVA/{208x1.73} plus 125%) which is 104, but I went up to the next size?
Lastly, do I need primary and secondary circuit breaker protection? I thought I did only because of the bonding of X0 and ground on the secondary side.
Any thoughts, advice, opinions would be welcomed. I'll read Article 450 in the meantime. Thanks!!
