Alwayslearningelec
- NJ
- Estimator
Can you tap a feeder in a trough and feed( two feed obviously) primary side of two xfrmrs( hit disconnect first)?
What types of splice connectors do you like to use in this situation ..splicing #250 to #3/0. Ilsco compression or mech??Yes the conductors between the feeder and the disconnect would be tap conductors so the appropriate tap rule applies.
Unless an irreversible compression type was specified we would use an Ilsco/Polaris type.What types of splice connectors do you like to use in this situation ..splicing #250 to #3/0. Ilsco compression or mech??
