Alwayslearningelec
- NJ
- Estimator
The springs also have rubber inserts so vibration isn't an issue.Absolutely. I would use rubber or fiber pads at the bottom instead of metal to metal contact to cut down noise from vibration though.
You're right that it is tight but there are no clearance issues although the photo may be deceiving. Also there are no anchors in the "grout line" as they are rods through the block.Whoever layed out that room was almost pushing clearance issues...
Almost. Seems like whichever side the secondary °90 ends up, it'll be tight..
Anchors in the grout line are annoying as well.
So its your tranny?You're right that it is tight but there are no clearance issues although the photo may be deceiving. Also there are no anchors in the "grout line" as they are rods through the block.
Yes. From a job about 8 years ago. The original installation had two transformers a 15 kva on top and a 30 kva the bottom. Then after they were all installed they changed the bottom one to a 45 kva which made it very tight but it did fit.Is it your pic?!
I wasn't.No need to get offensive,
Yes you did and I'm agreeing with you.i just said almost....
Sure you do...it is still on the wall.And i have no way of knowing if its allthread straight through w/squares on the back.
many electricians use fenders improperly.I would feel safer if the unistrut extended a few feet below the existing installation. Have seen workers standing on top of transformers performing work. Never used the nice guess you call them vibration dampers when I hung transformers off walls or from ceilings. On old questionable cinder block walls would use three 1/2" all thread on each strut piece thru the block with 1900 covers & a fender washer on other side.
