You can call it dump question: if I need to run (15) 20A/120V circuits to the yard and feed Xmas lights, tree lights....
the yard is probably 30 feet away from building electrical room - ground floor.
Should I install all above (15) circuits (or total of 30 if counting total hot and neutral wires) in a large conduit and run this conduit underground from building electrical room
to the yard, then terminate the conduit in a pull box. Then, run 1/2"C underground conduits from this pull box to electrical outlets installed by the tree
(Xmas light, tree light cord can plug into this outlet)...
If I run (15) conduits straight from panel to the trees...it sounds weird and kind of a mess when penetrating all those (15) conduits through building slab???
Any other better ways to do this conduit run?
Are there other methods to distribute circuits from large conduit into small conduits besides using a pull-box?
THANKS!
THANKS!
