rookie4now
I have a question about the X0 connection here. The copper strap is bonding X0 to the chassis. Is the current connection correct. The inspector said the the Ground needs to land on the X0 terminal. If that's the case I suppose I would need a double lug to land the ground and the neutral on the X0 terminal. He also said something that seemed odd to me. He essentially said that I needed to demonstrate that the building steel that we used to ground the transformer was physically tied to the service. I do very little work with transformers but I thought the building structural steel was a very common and accepted means of grounding.
Also, if anyone can recommend a good link for learning more about transformers I'd like to increase my understanding.
Thanks
Thanks
