Busarider29
- Saginaw, MI USA
I am running 120 VAC power to a sub panel from the main control panel. Both panels (Main and Sub) are mounted side by side on the same machine. The main disconnect on the Main panel switches power off to both panels. In this situation, do I still need to run yellow wire for the 120 VAC for the sub panel?? From my understanding, yellow would only be used if power to the sub panel remained on when the switch on the main control panel is shut off (which is not the case here). The sub panel does not have a disconnect switch and is shut off from the main panel.
Thanks,
Don
Thanks,
Don
