Split Bolt
- Northern Virginia
I just looked at a service change job on an older house. Normally, the ground rods will go in near the point where the SEC enters the house for convenience. This house has an overhead service and below the meter location is poured concrete that connects the driveway, carport, sidewalk and front steps. I don't want to drill 2 holes in the concrete and leave something that looks like crap right where everybody walks past on the way to the front door! I am thinking about fishing the supplemental grounding electrode conductor across the basement along with the grounding electrode conductor (the main water shutoff valve is on the other side of the basement) and driving the dual ground rods on the other side of the house. I can't see where this would be a violation, but wanted to put it out here to see if I'm missing something.
Also, while looking into this, I noticed this in the NEC (both '05 & '08): "250.53(B) Electrode Spacing. Where more than one of the electrodes of the type specified in250.52(A)(5) or (A)(7) are used, each electrode of one grounding system (including that used for air terminals) shall not be less than 1.83 m (6 ft) from any other electrode of another grounding system. Two or more grounding electrodes that are bonded together shall be considered a single grounding electrode system." Does this mean that I cannot drive either one of my 2 ground rods (supplemental electrode) within 6' of where the copper underground water main (grounding electrode) passes?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance!
Thanks in advance!
