kolyan2k
- United States
I've been working as an electrician for some time, but lately been doing it only part-time, and I dont do much services to begin with.....
This is in MA and new service needs to be 200AMP 2-meters. Existing is underground 100AMP with 14x8x6 t-box, 2-meters, everything is indoors. We have done several underground service upgrades in Boston and in all cases as I remember all we have done is connected everything to that existing old t-box and call it a day, then POCO decides if they what to keep that 100AMP underground cable or run 200AMPs to customers house (upgrade pipe and/or just wire). But I spoke to another electrician and he told me that I need to forget about old 100AMP service including the entrance cable, and just install outside new 2-gang 200AMP meter box with breakers, call POCO and tell them to run new service from the well. Can anyone comment on this? Do I reuse the old t-box, install 200AMP disconnect, run SER cable to 200AMP meter box outside, and then feed my panels? OR forget about 100AMPs, install 200AMP meter box outside, run feeders to panels, POCO does everything else?
2 other small questions. What is the minimum t-box size to connect two 4/0 AL SER cables? and I am guessing if I need to extend some existing panel circuits to run to new panels, AFCIs are not required ?
Thanks
Thanks
