Had a small "suprise" yesterday.
Adding a breaker to a Murry panel. As I went to place the cover back on, (you know, you hang the top over some pins and one screw holds the bottom of the cover in place), I placed the top in position...Pow!...short circuit. Since I was still holding the cover, so I pulled it back off to try to determine what happened. I looked at each breaker, and sure enough one (15A) was tripped. I followed the circuit up to a doorbell transformer sitting on the top of the panel. I looked and then looked again. The green grounding wire and the black (hot) conductor for the transformer were connected (together) to a pigtail that went to the breaker.
The transformer was sitting there with it's metal case at 120V potential.
It apparently was sitting on it's plastic mounting nipple and not making contact with the bonded enclosure until I bumped it with the cover.
I corrected the connection and said thanks because I had on a pair of good boots.
I asked the owner if anyone had installed a new doorbell transformer and she said "yes, I had the painter install it when he was here, he's a good friend and did it for me".
I told her that her "good friend's" stupid mistake could have gotten someone killed.
That tranformer was like a coiled snake ready to strike the first person who got too close.
I know that I should have killed the main before I opened it up, but I (like a lot of you) sometimes work hot if I'm in a hurry.
Luckily...all is well.
If I see that painter.....#$@%^&^%.
steve
steve
