"You can't use those"
peter d
New England
I once worked for a contractor that forbid the use of T-strippers. "They nick the wire." :D
I was also told: "Throw that level away." :mad: I'm not kidding.
Suffice it to say, I hated working for that contractor from day one.
Re: "You can't use those"
I wish I could find a way to strip wire that
doesn't damage the conductor.
I have a really good idea for a stripper that would not damage the conductor. But it's not particularly practicle.
And if I let the secret out it might become a manditory method, something AFI's, and I wouldn't be able to afford to do electrical work anymore.
I learned to strip wire with my kliens,Then I used a greenlee stripper with curved handles and love them,has a 6/32 and a 8/32 screw cutter built in.Yes if you are not carefull you can nick and/or cut through a conductor :cool:
How about a battery powered heating element grasping device where is first melts the coating off the wire and then follows with a quick scrubbing action. All in one tool, and takes 3 seconds. Nah. :eek:
I think it's important to understand just how much a conductor is weakened when it's nicked by stripping. Same reason stress lines are built into concrete. Sometimes it only takes two wiggles of a copper conducter to get it to snap off at a nick.
That's the whole reason I bought up that thread on wire strippers.
My sister invented and patented a tool for rough-in's in name of my father. It is called the C.R.I.T . Charlies Rough In Tool. It is available in Cali only. Not a big demand for it, but I have one in my bag. Nice tool. It has a klein style head with a small flat hammerlike device on one side for popping holes in fiberglass boxes and or driving staples. Also, it has a crimping device that is inside the cut of the tool, not underneath which makes it difficult. On one handle of the tool, it has a box cutter that retracts and the other handle has a hollow bottom for a marker or pen. it holds the writing device similar to how a compass holds one. Pretty neat but kinda heavy. She have the patent for 3 more years, so don't try to steal it. lol :D
Hey, melting the insulation for stripping is my idea aelectricalman.
It is a great way to keep the conductor intact. Batteries though, not a very good choise if you have an eight hour work day. I've had battery powered soldering irons. Perfect for throwing at stuff because they're hardly useful. But butane? I had a very cool butane soldering iron that only needed to be refilled with inexpensive fuel in order to continue the project. That's workable.
Edit: Sorry aelectricalman, I didn't mean to call you Allen.
[ March 21, 2005, 09:55 PM: Message edited by: physis ]
If enough of a "ring" is knitched into the wire while stripping the wire it can cause overheating just as a loose connection. We teach our Apprent. to "tear" the insulation away with the kleins rather than cutting into it.
It's all in the touch......
That it is Big John.
But it would be really nice to have a tool that removed the need for competence all together.
Did I just say that?
Did a trim out on a 4,000 ft home years ago and we had a 4 man crew,One guy was working for us for almost 6 months.His job that day was to install SD`S and inviso plates and can trims and bulbs.I walked past him in a hall and 15 minutes later he was at the same exact spot ;) good thing was that he was taught to leave a loop in all ceiling boxes.This was a 2 story with TGI trusses,wouldn`t that be fun ;)
arc a nice set of linesman's..then throw the t-stripper away. Once ya blow a nice hole thru the cutting edge the linesman's strip great..j/k
Actually I have every pair of kliens I have blown up over the years :eek: One pair was from 1975 in NYC doing a remodel and it was a dc feed for an elevator.The dc controled selinoid valves for a hydrostatic elevator.Circa 1915,after the sparks settled there I was with a pair of handles and the pivot point.That was it just handles.Scared the c__p out of me :eek:
I strip wires a lot like bigjohn said. I clamp the stripper down all the way and twist to make a weak point in the insulation. Then I take a second bite more toward the end of the wire, but I don't quite clamp down all the way. Then I pull and the wire tears at the first bite point.
Not bad for an engineer, huh?
Steve
I'll stop using T-strippers when you pry them from my cold, dead hands. I've tried all the gizmos and even the old fashioned way, with a knife and with linesmans, and there is no better way than with strippers. (Not those cheap $5 multi tools either, they will nick the wire.)
Why did you even go back for day 2 ?
I was young, and didn't know any better. I learned my lesson though, never to work for old timers that are set in their ways and refuse to learn new things.
I wonder if there are any of those guys here? :p
