- Lockport, IL
- Retired Electrical Engineer
Well, maybe you will believe it. Many of you have probably seen stranger things in your careers. Let me say instead that I am not yet ready to believe it.
I will try to put up a photo or two tomorrow. I am posting this only for entertainment purposes.
We just bought the house we have been renting for 8 months. In several earlier threads, I have talked about several of the house's other "entertaining" electrical problems. Part of the deal for the home sale was that the sellers would provide about half the funding for replacement of the main panel (Zinsco) and resolution of the problems. The contractor (a member of this Forum) is scheduled to do the work next week.
But yesterday I had a plumber replace the hot water tank and remove an old (much larger) tank that was part of a solar-driven water heating system. When the bigger tank was gone, I discovered an old receptacle outlet behind it, about five feet off the floor.
Let me start by saying that this portion of the house, including the solar water heater, was part of an addition to the house that was done about 15 years ago (before the people who sold us the house had bought it themselves). Here is the unbelievable part of the story:
? The outlet was two-prong.
? There was no cover plate.
? The upper half of the receptacle was broken (some plastic had cracked and had fallen off).
? The lower half had one "cord" plugged into it.
? The "cord" was constructed with 12/2 NM with ground.
? The white insulation of the NM was missing for about one inch away from the plug.
? The plug was three prong, but it was plugged into one of those "cheater adapters," so that it could be plugged into a two-prong outlet.
? From the point at which it plugged into the receptacle, the NM was dangled in open air above the solar water heater, and was run into a gap between the wall and the ceiling of the small closet in which the tank had been installed.
Are you ready for this?
? When I unplugged the cord, the things that lost power were two overhead lights ? ? ? two wall-switched overhead lights ? ? ? in the "new addition" section of the house.
? The area above the ceiling (in which the lights are mounted) is not readily accessible. I have no idea how the contractor is going to resolve this one.
